The rocker deco strips on my 70T seem to be riveted on from the outside. Is there a way to get to the back of the rivets. Sorry for the bad pic.
Thanks.
Ulrich
Thanks.
Ulrich
drill them out
ASSUMING, these are installed correctly, the normal procedure is to remove the endcaps, usually screwed on, (but could have been riveted) then pull the rubber deco insert out, then remove the sheet metal screws behind the rubber, then remove the sheet metal screws along the bottom edge.
Thank you. My deco strips have rivets along the bottom edge. Why? I guess I will find out when I get them off.Quote:
Originally Posted by edmayo
Does anyone know if the rubber insert is still available? I could use a set for my 66". Thank you in advance.
