4 Attachment(s)
Windshield wiper won't turn off
If I use the wiper for a couple seconds it turns off. If I run it more than a couple minutes it won't turn off. In fact in the off position it runs faster than the fast position. The only way I can get it to stop is pull the fuse. I then reinsert it shortly a few times tell I hit the right cut off spot then leave the fuse in. The next time I use the wiper I start the whole process over again.
Here are a few pictures of the wiring. I tried going around the noise suppressor. Same thing.
Chris
