What about the covers??
i have been working on that , issue is i have not found one to copy ....so if anyone has one i can borrow PLEASE let me know
John,
I have one on the Gold Coast. I understand you are coming my way. You can take it back with. As long as I get it back in the future.
Cheers
Tim
pm sent cheers
Before i head off to the land of the long red dust cloud ....
Don't forget divider plate in top tank. Gled
Another request for the smaller 1969 fitting size please!
Alan
New Jersey
Divider plate to be tig welded in after casting
Big Thanks to tim on the gold coast for taking the time to show me his work in progress and passing on a genuine stone guard with the rubber seal still attached . this will be heading to the 3d scanner and on to production to complement the behr coolers asap.
Why don't you include the in/outlets threaded boss into your casting?
You could then avoid manufacturing the inserts, and welding them onto your casting.
Pattern cost would be pretty close.
Machining: I think you would have to drill your castings before putting the threaded insert prior to welding. Right? If yes, Machining would be about the same: drill the correct size then, tap it.
Look would be better IMHO, and at the end of the day, you'll save a few $$ over production.
Parts would also be stronger.
Same comment for the divider plate. You're loosing all the advantages of the casting. Unless, I understood nothing about this subject, in this case, all my apologies for stupid comments.
If I am right, and if my comments aren't clear, send me a STEP or IGES file, and I'll design you what I mean. (Don't need accurate model, I don't want to steal your work)
Have you considered 3D printing for the patterns? You could cut your costs over CNCing them. As long as you don't plan to produces hundreds of them.
I have no interest in these parts. But if I can help a littler bit, I'd be happy =-)
Just my 0,027 cents (0,02€ converted)
Olivier.
