Quote: Originally Posted by moito the one with the bracket is kind of 64-66/67ish(bracket discontinued during MY67 if i remember correctly) if the 2nd one you have is(more or less) identical to the other one (minus the bracket) its for the rest of MY67. (nerd info: there is at least 8 different versions for SWB---multiplied by all available vinyl colors ) The "brackets" continued thru the 68 model year. Regards Jim
Quote: Originally Posted by Jim Breazeale The "brackets" continued thru the 68 model year. Regards Jim taken off from my 68L...not sure if the doors even had the slits...need to have a look... still have the doors ......somewhere
68 911 RH side. 68s are "one year only". They look like a 69 and later part on the outside but 65 - 67 on the inside.
