The mr clean system uses water filtation to remove the minerals from the water. It also incorperates soap. I use a towel to help remove the grime, rinse then use the filtered water. The the car is spotless after use. No drying. The cartridge is good for about six or seven washes. A new cartridge is about 10.00.
