5 Attachment(s)
Brakes, wheels and tires: Zuffenhaus RSR-look brake package
These Zuffenhaus brakes use 930 piston sizes front and rear, which means they can also use 930 piston o-rings and seals. Combined with their aluminum brake hats and Brembo floating rotors, you save a lot of un-sprung weight (but loose the stock e-brake). They look cool, too!
Attachment 281593
Attachment 281594
Attachment 281595
Attachment 281596
Attachment 281597
4 Attachment(s)
Brakes, wheels and tires: attention to detail
Aaron's attention to detail when fabricating and installing the brake lines is amazing!
Attachment 281599
Attachment 281600
Attachment 281601
Attachment 281602
1 Attachment(s)
Brakes, wheels and tires: RSR-style e-brake assembly from AASE bros.
Aaron said these were a LOT of trouble to install...
Zuffenhaus is working on their own version of the RSR e-brake, but last I checked they were not yet available.
Attachment 281603
1 Attachment(s)
Brakes, wheels and tires: 15" X 8" and 9" Fuchs with RSR finish - found here
I found these advertised here on the forum. They already had the RSR finish on them, reportedly done by Weidman many years ago.
Attachment 281627
They are standard Fuch offsets, and there are 25mm spacers in front and 15mm spacers out back.
1 Attachment(s)
Brakes, wheels and tires: 225/50/15 front, 235/50/15 rear Toyo R888 tires
Many of you know how hard it is to find a good 15" tire. Stock tires on a long hood 911 are about 25" in diameter, and that's what I wanted to stick with for various reasons including aesthetics. The choices available today are either too tall (26.7") too short (23"), too track-focused for my liking (Hoosiers) or too darn expensive (Michelin TBs). Actually, I would have bit the bullet and used the TBs but even there the only real option for this car would have given me rear tires over 2" wider than the fronts - more than I wanted. Soooo...it's Toyo R888s. Not exactly what I wanted, but I think the look is at least not completely objectionable and they perform very well, at least in the dry-weather street driving I've used them for so far.
Attachment 281632
1 Attachment(s)
Transmission: ’76 915 with magnesium case
I wanted an 8:31 ring and pinion for strength, and a magnesium case for light weight. The changeover from the 7:31 to the 8:31 happened during model year 75, and the change from a magnesium to aluminum case happened during model year 77. '76 was also the first year of an improved input shaft guide tube, so 1976 is the sweet spot, and Aaron found a good one to use as the basis of this build.
Attachment 281633
1 Attachment(s)
Transmission: full suite of Wevo internal modifications/machine work
I don't have any close-up pictures of the machining that Wevo did on the 915 case, but you can read all about it here: http://www.wevo.com/Products/Transmi...aseSystems.htm, though we did not need the guide tube upgrade because we are using a '76 case. We also used Wevo's bearing retainer plate.
Attachment 281634
1 Attachment(s)
Transmission: Wevo differential side covers
Nice piece of alu.
Attachment 281789
3 Attachment(s)
Transmission: new gears from Guard Transmission
Matt Monson at Guard Transmission gave me great advice on gear ratios and I think they worked out perfectly. I bought three new gears, and used the stock 1st, as well as the stock 3rd gear as the new 4th gear. I bought a somewhat-shorter 5th gear - my goal here was not to have the ideal RPM drop between 4th and 5th which would have resulted in a far shorter 5th gear, but to be right at the beginning of the engine's power band when cruising at 75MPH. As you can see from the gear chart, 75MPH in 5th is at a comfortable 3600RPM at which point the engine pulls strongly. For me, it's perfect. Aaron had the same comment on 5th gear when he first drove the car, though he thought the jump between 3rd and 4th was MUCH too big...but that's because he accidentally used the stock 4th gear rather than the stock 3rd gear for the new 4th gear (if you follow me...) the first time he assembled the 'box...whoops!
One minor annoyance is that the new gears are somewhat noisy, though I only really notice in 5th. Matt explained that while these are still helical cut gears, they are optimized for strength and durability rather than noise and vibration like the stock gears. It's not bad enough to make we want to revert to a stock 5th...but it's something to consider.
1st: stock 11:35 (3.18)
2nd: new 17:35 (2.06)
3rd: new 19:30 (1.58)
4th: former stock 3rd gear 23:29 (1.26)
5th: new 27:25 (0.93)
Attachment 281522
Attachment 281523
Attachment 281524
1 Attachment(s)
Transmission: OS Giken ‘superlocking’ differential
I did a lot of research on limited slip differentials and found many experts who dismissed the OS Giken diff without ever having used one, but many others using them on street and track cars who gave them strong endorsements. It automatically varies between 0 and 100% lockup on both acceleration and overrun (braking). After a few months using this diff, I am really impressed - it is very quiet and seems to be providing excellent traction out of turns and incredible stability under heavy braking, but is completely disengaged when puttering through town.
Attachment 281790
