Results 1 to 10 of 20
Thread: 1966 911 gearbox questions
    Senior Member Jon1966's Avatar
    Feb 2014
    Herts, UK
    Hi all,
    In trying to address an oil leak from the gearbox on my 1966 I ordered new oil seals but when trying to refit the drive flange it seems to push the seal in about 5mm too far.
    This is the flange [ ATTACH=CONFIG]289920[/ATTACH]
    It measures 125mm and has no markings. Flange part is 50mm, first "step" (forgive my ignorance of correct terms) is 15mm, shaft is 35mm and splined part is 25mm.
    The box is number 519 1809 with casting number 901 301 101 2R
    It has a ZF limited slip diff.
    Is the drive flange correct? Too short?
    Jonathan
    Aug 2009
    SF Bay Area
    That is the wrong flange. The one you pictured is for a regular diff. The flanges for a ZF ltd slip have splines on the inside ot on the outside like the one you show. Just take a look at the trans and you will see what I mean. Good luck finding flanges for your limited slip!
    One more thing. If those flanges were in your trans, you don't have a ltd slip.
    Jim
    Quote Originally Posted by Jon1966 View Post
    Hi all,
    Jonathan
    Jonathan
    That is not the correct flange for a 1966 901 ZF limited slip. 1966 901's have female flanges (actually I think it's 1964-1968 have all female flanges).
    So:
    - or you have later gearbox (1969)
    - or you have a std ZF diff (non LSD)
    Is your gearbox aluminium or magnesium? Pictures?
    Richard
    Feb 2014
    Herts, UK
    Thanks....do you mean I don't have an LSD because the flanges couldn't have fitted or they could have but will have damaged it? The box was recently rebuilt but I haven't been able to speak to the chap that did it. The slightly old FiA papers that came with the car specify it as having a ZF LSD but that could no longer be the case.
    This is a female LSD flange. It's "opposite" from yours.
    69 and up (magnesium gearboxes) have "male" flanges, although slightly different than the one you are showing
    Richard
    Feb 2014
    Herts, UK
    Will get some more photos what back with car
    Aug 2009
    SF Bay Area
    Yes, those flanges are not at all compatable with a ZF limited slip diff. See the pictures posted by PreS. Your flange is for a regular diff. and the picture of your trans showes a regular diff confuguration.
    Jim
    PS: your flanges need a seal in the middle of the flange. If that is missing it is probably the source of your leak.
    Jim
    Feb 2014
    Herts, UK
    Thanks - any idea what would explain the oil seal being pushed 5mm too far in?
    What do the gearbox numbers quoted above tell you about the box ?
    The FIA papers state "ZF Lamell" - could well be (and seems to be the case) that its just a standard diff.
    Feb 2014
    Herts, UK
    Few more photos. I am confused....the 902/16 stamp suggests a 912 box from 1969 but the 901 stamping something different?
Size:  114.9 KBName:  front2.jpg
Size:  167.8 KBName:  front3.jpg
    Aug 2009
    SF Bay Area
    What is the stamped number on the bottom of the trans. It would read something like 901/0 and also the transmission number will be stamped near that type number. Please take pictures of the whole trans. I don't think you have what you think you have.
    Jim
