Thread: Erratic oel pressure gauge
    The gauge needle sometimes jumps all over the place. Does anyone have any thoughts on why this is happening?
    RGruppe member 445
    Sounds like a ground issue. Check the connection(s).
    It's the wire
    Jan 2011
    DFW TX
    I recently had my gauge reading randomly higher than normal... I "exercised" the 14 pin plug at the back of the engine bay console and all was well again. There is also the one at the front of the console but it doesn't get wet as often.
