Thread: 71 E Sportomatic help
    I'm in the process of inventorying the parts with my sportomatic and can't find how or what component is used to drive the convertor oil pump on the right side cam.
    I have the pump and housing with a drive pin but don't have the piece that bolts to the cam. Any help in identifying this part would be greatly appreciated.
    The downside of buying a car in pieces. Missing soooo many fasteners.
    Thanking you in advance.
    Best to all,
    Rusty
    Port Macquarie, Australia
    Rusty, the camshaft of a sporto has two roll-pins driven into the end of the cam (nothing is bolted) - they become drive pins that turn the little arms on the pump input shaft.
    John Forcier
    EarlyS #1987
    Restoration Saga
    John, thank you for the clarification. I saw the tensioning sleeves on the PET program.
    Moving forward.
    Rusty
