Thread: Poor throttle response
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    So as I prepare for the drive to Cambria, I figured I'd spend some time on the car and
    see if I can figure why my throttle response has been "lacking". Pulled the cap and my
    rotor barely budges. YIKES! No to little spark advance. Pulled the distributor, took it apart
    down below the points plate. Couple questions...Does the drive gear pin press out or does it need
    to be drilled? If I press it out, can I re-use it? (I'm running out of time to order parts)
    I cleaned it up the other night (the best I could without removing the drive gear)
    and put a dab of tri-flow lube on the pivot points. After sitting a day, I checked the rotor,
    and it feels stiff again. Should the weights be dry? They were snapping back an hour after lubing.
    Thanks in advance,
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    There should be a felt wick under the rotor (down in the distributor shaft) That is where one shaft rotates on another and should have oil put on that wick every time the points are serviced. Take the wick out and put your favorite lube down the hole and keep working the shaft. That might free it up better. The pin for the drive gear is peened at both ends, so needs one end ground down before driving out, generally NOT reuseable.
    Sep 2006
    South San Francisco
    Thanks Ed,
    It's currently running an optical pick-up. I sprayed some MAF sensor cleaner thru it
    to "dry" it out. The weights swing freely now. It needs to come apart for a full service.
    Thanks for the heads up on the pin.
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
    Feb 2010
    San Francisco, CA
    I've got an industrial sized tube of bosch distributor grease if you want to borrow it Dave.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Sep 2006
    South San Francisco
    Thanks Kent...think I'll have it gone thru
    between Treffen and Monterey. I want someone
    with a distributor machine to dial it in.
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
