Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: project Behr - reproduction fender cooler
  1. #21
    Jun 2013
    lynchburg, Va
    What about the covers??
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
  2. #22
    Sep 2008
    Auckland , New Zealand
    i have been working on that , issue is i have not found one to copy ....so if anyone has one i can borrow PLEASE let me know
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  3. #23
    Senior Member timgt3's Avatar
    Gold Coast, Australia
    John,
    I have one on the Gold Coast. I understand you are coming my way. You can take it back with. As long as I get it back in the future.
    Cheers
    Tim
    Tim Pritchard
    1970 911S (resto underway) http://www.early911sregistry.org/for...ge-1970S-resto
    1976 Carrera 3.0 Group Sc Race Car
    1969 911T Group Sb Race Car (Sold to a good home)
  4. #24
    Sep 2008
    pm sent cheers
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  5. #25
    Sep 2008
    Wink
    Before i head off to the land of the long red dust cloud ....
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  6. #26
    Don't forget divider plate in top tank. Gled
  7. #27
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Another request for the smaller 1969 fitting size please!
    Alan
    New Jersey
  8. #28
    Sep 2008
    Divider plate to be tig welded in after casting
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  9. #29
    Sep 2008
    Big Thanks to tim on the gold coast for taking the time to show me his work in progress and passing on a genuine stone guard with the rubber seal still attached . this will be heading to the 3d scanner and on to production to complement the behr coolers asap.
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
  10. #30
    Jan 2011
    Sunny Southern France
    Why don't you include the in/outlets threaded boss into your casting?
    You could then avoid manufacturing the inserts, and welding them onto your casting.
    Pattern cost would be pretty close.
    Machining: I think you would have to drill your castings before putting the threaded insert prior to welding. Right? If yes, Machining would be about the same: drill the correct size then, tap it.
    Look would be better IMHO, and at the end of the day, you'll save a few $$ over production.
    Parts would also be stronger.
    Same comment for the divider plate. You're loosing all the advantages of the casting. Unless, I understood nothing about this subject, in this case, all my apologies for stupid comments.
    If I am right, and if my comments aren't clear, send me a STEP or IGES file, and I'll design you what I mean. (Don't need accurate model, I don't want to steal your work)
    Have you considered 3D printing for the patterns? You could cut your costs over CNCing them. As long as you don't plan to produces hundreds of them.
    I have no interest in these parts. But if I can help a littler bit, I'd be happy =-)
    Just my 0,027 cents (0,02€ converted)
    Olivier.
