Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: MFI Fuel pump-performance and modern replacement
  1. #11
    On the Carter fuel pumps website the P90021 comes up for 1969 FI cars. Looks like the 15gph flow which is in spec but no operating pressure given. Maybe this could work also?
  2. #12
    Aug 2011
    Eugene, OR
    I don't think there are any pumps which are a direct replacement for the 3-port factory pump. All the aftermarket pumps I've seen require blocking, plugging or removing the return line from the pump.
    - Arne
  3. #13
    Thanks Arne. I figured so. I guess I just need to find something 14psi and 125 L/hour specs
