Results 1 to 10 of 11
Thread: Engine number help. 901/02
    Sep 2009
    UK
    I have been given an engine number that is a bit of a curveball. It is a Magnesium, not aluminium 901/ 02 engine. Engine number:901283. Also marked, 55/93. This is all the detail I have at the moment.
    Has anyone come across anything like this before ?
    Thanks in advance.
    Dave
    Oct 2008
    Burford, ON, Canada
    I'd need to see photos. 901283 was not a mag case engine, nor was it a 901/02. I would be very suspicious if you have no further info.
    Sep 2009
    UK
    Thanks Dave.
    I hope to get some pictures at the weekend. Where and what year was, 901283. And what type number ?
    Aug 2009
    SF Bay Area
    That number would be for a 65 engine with type # 901/01. Something is very fishy!
    Seems to be a "reprinted" serial number. Do you have any picture.
    On alu case serial number are on the rear side, on mag case, serial is on the right side.
    67S+924
    Sep 2009
    UK
    I will get pictures at the weekend. Thanks for the info guys.
    Please note also the casting numbers on the case halves.
    Richard
    Sep 2009
    UK
    Here is what I have. communication or photography is not his strong point. I would appreciate some opinion from the board.
    A later (68) S case that has been restamped (or given) an earlier number (BTW the font's of the serial number are not very Porsche ..).
    Richard
    Oct 2008
    Burford, ON, Canada
    I agree, this is build 15593, so a 901/02 case where the original serial would have been near 4081450 or higher. It is too bad the original # has been lost.
