Results 1 to 7 of 7
Thread: Originality/restoration question
    I have a 72 t, gulf orange, nearly all original, however in the 90,s someone got heavy handed with the black spray paint, especially the wheels, and wheel wells.
    Question, what was the original color of the brake rotor backing plate? Were they painted black or should they be the gold plating? I notice the Porsche replacements are black.
    Any thoughts?
    Thank you.
    Gold zink. gled
    Aug 2009
    SF Bay Area
    Yellow zink
    Jim
    Jun 2012
    London, Ontario, Canada
    This is an unrestored '73, but same idea. Should help you clean up your car. https://plus.google.com/app/basic/ph...ource=appredir
    Ravi
    Early 911S Registry # 2395
    Very helpful, thank you. In 72' wheel wells and underside painted black? Wurth stone guard type finish?
    Also my backing plates have lost most of their yellow zinc, any suggestions?
    Also the heater valves are reddish in color any suggestions on spray can similar colors?
    Thank you.
    Quote Originally Posted by Ccamut View Post
    Thank you.
    At the risk of stating the obvious,,,,,get them replated. For the heater valves I use red oxide primer with clear over it. Very close to original.
    Jul 2006
    Corvallis, OR
    Thank you.
    I have the magic paint for this. Check my thread in the general section under the restoration of 9112300023
    72S, 72T now ST
