Thread: How do i remove these?
    Mar 2013
    Surrey, UK
    I'm fitting a 79SC engine into my 70T. the engine was a sportomatic, but i will fit it to my manual 915 gearbox.... I thought this was going to be easy, however, it seems to be getting more complex. Latest problem is the removal of 2 pins on the camshaft. These used to drive an oil pump that was connected to the sporto gearbox. I need to remove them to fit the plug that goes into the end of the camshaft housing. Any idea how i do that?
    Here's a pic of the offending pins at the end of the camshaft
    Paul
    #2264 classic's Avatar
    Gold Coast.
    Paul,
    They're just a press fit pin. Get some small vise grips on them.
    Tony
    Mar 2013
    Surrey, UK
    Thanks Tony. I'll try that tomorrow
    Mar 2013
    Surrey, UK
    Just tried pulling them out with some mole grips. Result: pins are now crushed but won't move - not good. Any other ideas?
    Gold Coast.
    If they're not just coming out with you twisting them, I'd try some heat. They should just twist/pull out.
    Tony
    Sweden
    Tap a thread in the pin and fit a bolt in it, it doesn't widen the pin as a metal screw will. Then pull/slide or pry it out.
    Mar 2013
    Surrey, UK
    After a lot of perserverence and wiggling, i finally managed to extract the pins. I then gently tapped in the replacement plug with a small amount of gasket sealant. Many thanks for your advice.
    Paul
    Gold Coast.
    Nice job Paul
    Tony
