Thread: Tail light wiring
    Tail light wiring
    Hi all-
    Do I have this right? Housings were trashed when I got the car so I don't have a reference point.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Looks right, but mine's a ROW car so a little different.
    You can plug it in and test your hookup, if you still have everything hooked up in the car. You won't hurt anything.
    Tony
    Aug 2011
    New York
    It appears to me that the socket I highlighted in yellow is upside down. Did you remove and reinstall it? I believe the Green and Gray/Red should be towards the inside, and the Black/Yellow should be on the outside.
    E Sully
    1973.5 911T
    Apr 2011
    N.Calif., south of SF
    Maybe this will help. It is from a 1969 911E & 911S wiring diagram
    Name:  Screen Shot 2014-05-31 at 3.20.10 PM.jpg
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    The Netherlands
    wiring
    This is what I found inside a rear US taillight: although I have seen the grey red and black /yellow crossed. the green is on the grey red.
    Cees
