Results 1 to 10 of 13
Thread: DIY : Restoring Hood lights (Phares Boules)
    Aug 2012
    France
    After sharing the restoration of my toolbag, I would like to do the same with one of my numerous pair of Cibie Pallas.
    I have several pair of these very cool hood lights. I went mad few months agao and bought many original used pairs. It is now time to make them nice again.
    Decided to take the red pair, fully painted in red, heavy thick paint.
    First of all, have dismounted the light to check condition : very good
    Then checked if the chrome is still here - using a soft Dremel coper brush - the chrome has faded on the outer but still bright/shiny on the inner side. Both will get a new chrome treatment.
    I decide to use a Restom chemical paint remover for the bowls and the circles. I did it 3 times due to the thickness of the red paint. will see tomorrow the result of the 3rd layer.Name:  WP_20140610_012.jpg
    In the mean time, I have ordered 2x H1 Bulbs, the electrical harness, and few new special bolts (monancienne.com)- ordered 2 Pallas Mounting plates from our friend ST-Classic/advtracing.
    O-G 26 - Early911S 2407
    Aug 2012
    France
    while waiting and had nothing to order more, I cleaned the inner optic mounting plates
    May 2011
    Chelsea, Québec
    I have a question whether gentle bead or soda blasting would be better than a Dremel on the chrome, or even paint stripper?
    Member #1616
    Aug 2012
    France
    Quote Originally Posted by StephenAcworth View Post
    maybe, I will try on the next set. However, I plan to re-chrome those ones as they were faded, probably due to the paint, as surface is really clean.
    Xavier
    Jan 2011
    Sunny Southern France
    The brush itself could have caused this fading...
    The chrome was perhaps perfect under this paint. You could try to repolish it with polishing paste and fabric wheels... (un touret à meuler équipé de roues en tissus ou en feutre et de la pate spéciale pour polir. Si ne chrome n'est pas piqué/écaillé, ca peut marcher. Ne JAMAIS utiliser quoi que ce soit d'abrasif sur du chrome! Cata garantie!)
    May I ask just for my curiosity if you could show how the mouting system of the light itself works ?
    Thx
    Olivier.
    You will find few infos/pics there, i've restored many of them ;-)
    http://www.early911sregistry.org/for...%E9+hood+light
    Aug 2012
    France
    Quote Originally Posted by Olivier View Post
    Thx
    Olivier.
    I use 2 different ways of removing the red paint, and the chrome was faded on both. :-( I tried to polish them : no joy. Rechrome is on its way :-)
    Mounting system of the bulb ?
    Quote Originally Posted by OliveR View Post
    Thank you.
    Xavier
    Aug 2012
    France
    Thx
    Olivier.
    IS this what you are looking for ?
    Xavier
    Are the 3 little plastic sockets available that are snapped into the lense retaining ring?
    Jan 2011
    Thanks Xavier, exactly what I wanted to see!
    Olivier.
