Thread: Could use a photo of fuel line routing, etc ('67)
    Nov 2006
    S. F. Bay Area
    Now that I have acquired this little gem, I'm hoping someone will share a photo showing it's installation. Thanks
    Brian
    S Reg #1032
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Brian,
    I can snap a photo tomorrow if somebody else doesn't.
    But if you look at the rear crossbeam, where your shocks are mounted. Along the face of that where the seam is there should be 2 metal tangs, one over towards your left shock, and one towards the middle.
    The streight section goes towards your pump, and positioned the feed lines would point towards your carbs.
    Tony
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    there are metal straps on the cross member(where the rear shocks are mounted)...they hold the tube.
    f.
    Nov 2006
    S. F. Bay Area
    Got 'em…thanx guys.
    Brian
    S Reg #1032
    Registry Member #2679 friggens's Avatar
    Jul 2013
    Albuquerque, NM
    I found that I had to -carefully- with tubing bending sleeve (looks like a screen door spring) bend the tubing to match the curve of the body to neatly fit undter the tabs then also point toward the R carb just so. Mine may have been more misshapen than others. It'll be nice to see yours installed
    cheers -
