Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 73 S replacement fuel tank (DANSK) fitment issue..
  1. #11
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    I had the same problem, and what happened was that they had sent me the wrong tank, also like Ed Mayo says, after market parts are not perfect, even from Danks.
    Solved the problem by having them send me another one.
    Also this time of year, every one here is getting ready to close for vacation, so response could be late.
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
  2. #12
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    got one of this tanks recently...so they are still out there
  3. #13
    Sep 2009
    UK
    Bump, anyone come up with a better solution to this dansk tank bulls up. ? An adaptor maybe.?
    Dave
  4. #14
    Mar 2016
    U.K.
    Dave, I know the unions on the back of my tank were repositioned by Chesterton's for this reason. Kind regards, Gitesh
  5. #15
    Sep 2009
    UK
    Hi Gitesh, yep, looks like i need to fire up the grinder and welder again.
    Dave
  6. #16
    Sep 2009
    UK
    Brainwave after the 4 am piss. Blank the middle one. Use the other large plug.... Bingo. So, i will use an old mesh filter fitting, no mesh as the return. Who said lying awake was bad for ya.
  7. #17
    Double trouble, Dansk and repro. I bought one and knew about the problem, cant beat the price.
  8. #18
    Make every effort to make the Dansk work because there aren't many options.
    A couple of years ago I pulled my CIS tank and installed an RS tank which utilizes two fittings (in-out). Plumbing is easy because it rides low in the car. Of course this required the services of Keith Walters at Zuffenhaus who provided a skid plate to protect it. I called it a wash. No chance of rust.
    Early S Registry #235
    rgruppe #111
  9. #19
    How about this poor guy? CIS tank. Not easily cleaned.
    rgruppe #111
