How the the car hobby in Poland these days?
Ted Zombek
Ted Zombek
Ok!
Now I need to fix situation around the doors...
What is correct hood badge for 65'? With orange or red strips?
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
For 1965 through 1973 Porsche 911s and 912s, the hood crest had orange stripes. See http://www.porsche.com/usa/accessori...ditions/crest/
Jim Alton
Torrance, CA
Your car, chassis # 302836 is a 1966 model year car built late in 1965. The engine, number 900867, is probably from a 1965 model year car with chassis number around 300796 (my car, chassis # 301382, came with engine # P-901505). Engine 900867 would originally have had Solex carburetors and the engine originally in you car also would have had Solex carburetors (Porsche switched to Weber carburetors around February 1966).
So, if your engine is in its original configuration, it would be "correct" for your car.
You mentioned you now have a red shroud on your engine. It would originally have had a black shroud. It looks like you now have Weber carburetors, be advised that switching back to the original Solex carburetors requires lots of hard-to-find parts: carburetors, manifolds, carburetor linkages, air cleaner, and the "tandem" fuel pump. I would put that off until later.
If I were working on your car, I would start by repairing the bodywork. Also, you need to have complete engine shrouds so all the cooling air goes into your engine. This is from PET:
You need (at least):
# 5 901.106.321.01 HOT AIR SOCKET /L/H -67 1 911 /S
# 6 901.106.036.01 HOT AIR SOCKET /R/H 1
Jim Alton
Torrance, CA
I'm not really understanding the timeline on this thread, which jumps from 2014 to 2013 and back again. But anyway, from the photos, you have a lot of bodywork to do before you need to worry about the hood crest.
Amazing answers Jim! Thx a lot. Yes I have webers now. I am still looking for original engine and hope to find it.
Methinks I wouldn't not switch to the Solexes again, because it's reputation is worse.
I will start bodywork right now.
Another small question.
Flywheel and clutch are missing. Which flywheel is the the best? Oem one or lighter replacement. Any suggestions about clutch?
Are oversize pistons available or any other repair way if the engine is seized?
I'm not at all an expert on performance modifications, so if you plan on a highly modified engine you probably need to get information from folks other than me. But...
SOLEX Carburetors
My car has its original Solex carburetors and I've always thought they worked quite well, There might be a slight flat spot around 2,500 rpm, but there's so little torque below 3,000 rpm it's hard to tell. I should point out that Porsche tried three different sets of carburetor jets in the Solex carbs. Here they are from the little spec book:
Maybe the original jets (up to engine # 900323) didn't work very well. At least with the fuels we have in the USA now, the second set works well. I've heard that the third set of jets (after engine 90360) cured all the problems, but Porsche had already signed the contract with Weber.
There is one problem with the Solexes: they depend upon the mechanical tandem fuel pump to fill the carburetors (the electric pump fills a float chamber in the intake manifold) so starting the car after it's been sitting and the fuel evaporates from the carburetors can be challenging. It's the same problem Porsche 356 owners face.
There is one big problem with going back to Solex carburetors. As the values of the early 911s have increased, many people have sought to return cars to absolutely original configurations. The prices of Solex carburetors for these cars (not to mention air cleaners, linkages, and tandem fuel pumps) have gone up. I've heard that a set might cost on the order of US$ 5,000.
Flywheels
A flywheel is an odd thing to go missing...
If you aren't making a lot of performance modifications, I don't see any reason to go with a lightened flywheel. The throttle response of the stock engine is incredible!
One thing I should point out about flywheels in the early engines is they don't have the same teeth to engage the starter as the later engines. Here's the diagram from the little spec book which deals with flywheel resurfacing. Note what it says about gear tooth modulus.
Make sure the flywheel you get matches your starter. In the terminology used by American Volkswagen enthusiasts, the '65 engine has a 6 volt flywheel. The flywheel which was originally attached to the engine you have now would have had the unusual 2.5 gear tooth modulus. Maybe it was removed to be put in another old car or maybe they couldn't find a starter that would work with it.
The stock clutch works very well with a stock engine.
Pistons and Cylinders
There are a lot of suppliers of pistons and cylinders for early Porsche 911 engines. Mahle makes sets, as does LN Engineering. Wössner at least makes pistons.
I'm not sure how much oversize you can go without machining the cylinder heads or the case. If you increase the displacement A LOT you may need to change carburetor jetting or get cylinder heads with bigger valves. You can probably switch to the 84 mm pistons (for a 911E) for a 2.2 liter displacement without too much difficulty, but check with an expert.
There's nothing at all wrong with keeping the engine at 2 liters and the car might be more valuable if it's more original.
Jim Alton
Torrance, CA
I have limited sources for this (my car has vinyl seats with houndstooth) but Charlie White's website http://derwhites356literature.com/De...iterature.html shows samples of 1966 vinyl and houndstooth inserts (search for "1966 Porsche 911/912 Color and Interior Sample Book" about a third of the way down).
The vinyl looks very different from those photos in the 1965 brochure--it's sort of a basketweave.
Jim Alton
Torrance, CA
