Page 14 of 14 FirstFirst ... 4121314
Results 131 to 131 of 131
Thread: Fire totals Speedster, RS, RSR
  1. #131
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    Quote Originally Posted by fourteenten View Post
    Doubt it is X ray, more likely magnetic, like NMR or MRI based measurement, nuclear magnetic resonance. https://regulaforensics.com/en/produ...n_number/7505/
    Cees
    This magneto-optical procedure is a good way to identify re-stamping after grinding off the stamping for the VIN number switch.
    To assess the originality of the chassis, I would recommend the following approach for high-value vehicles:
    1. Magneto-optical process to detect re-stamping after grinding off a VIN number - non-invasive
    2. X-ray spectroscopy of
    - metal sample of the VIN stamp area and
    - metal sample of the trunk floor panel and
    - metal sample of the dashboard
    The results of X-ray spectroscopy should be compared with each other and with verified time period metal sheet samples.
    The metallurgical compositions of automotive sheets have changed over the last 60 years, which can be detected by X-ray spectroscopy, but it is an invasive process.
    No doubt, a couple of restored cars would fail this test.
    BR
    Claudius
