View Poll Results: What are your engine temps?
Voters
38. You may not vote on this poll
  • 180 or so
    9 23.68%
  • 180-200
    18 47.37%
  • 200-220
    11 28.95%
  • 220+
    0 0%
Results 1 to 10 of 17
Thread: Oil Temperature Poll
    Oct 2012
    Minneapolis
    Just curious as to what everyone is experiencing for oil temperatures, what they are doing for cooling, and what oil they are running. I run liqui moly 10-60, and my oil temps at freeway cruising are around 210-225 in 85 degree ambient temps. (3600rpms/70mph)
    I have the euro brass front cooler. I also have the smaller, SC fan pulley.... wonder if that matters?
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    180-190. Oil emps normally track outside temps. I only get up to 200 in stop and go traffic in 100 weather. I use Castrol GTX 20-50. 1970 911 with front oil cooler.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    South Florida Street Driven 2.4 T with Brad Penn 20/50 and no auxiliary cooler.....
    November through March 180-190 and April through October 190-200.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Car runs cold-cold-cold . . . . takes >15 min to even warm up, and never gets much above 180 --- ever
    Stock everything + Brad Penn 20W/50
    I can second this (2.2S) but with Castrol Classic 20W50. Hottest I’ve ever seen was 185°F on a 100°F day. Thought the thermostat(s) were broken but they all work as they should...
    Sep 2008
    Auckland , New Zealand
    never over 180 , brad penn oil and carrera front cooler on 2.4s BUT interestingly another 2.4s engine just rebuilt with added carrera cooler never runs under 200?
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Jun 2013
    lynchburg, Va
    2.7 RS clone motor with oil lines but no front cooler. Usually around 180 in 70 degree weather on BP 20-50. On rare hot 90+ days can get up to 210 on fast 5000+ RPM uphill freeway runs.
    In comparison have a 3.0 SC mod into 3.2 with hotter cams and 10:1 comp pistons. Front turbotrol cooler and it runs 200-210 with same oil and 220-230 when run harder in hot weather.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    Just above 180 normal ...
    210 in the heat and/or driving hard....
    Much hotter then that at a SoCal track in August...
    But even at 210, it recovers so fast that in 20 min. I'll have to use the hand throttle to start it....
    These old cars run damn pretty cool.....
    - 2.7 punched 2.4S with '72 small radiator type front cooler ... 20/50 Brad Penn
    Dec 2008
    Woodland Hills, CA
    Massaged 2.0 with 2.2 PCs and DC-30 S Mod cams. No auxiliary cooler. BP 20/50... Hangs around 210
    Interesting tidbit...
    Rate of conventional oil oxidation doubles for every 18 degrees F above 150 F
    Peter Kane
    '72 911S Targa
