Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 73
Thread: 225mm Magnesium Small Fan Housing...
  1. #41
    I hope Ben will dispense with Marelli advance system with rotor attached directly to main shaft and use a more friendly rotor indexing system like Bosch. While he is at it, I hope he dispense with 4 points and builds a trigger compatible with Bosch 3 pin. Gled
  2. #42
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    Hi Gled,
    Ben offers two types of distribiutor….one is a less expensive option with Bosch type internals however his main focus is producing parts that mirror the original in every detail that will be indistinguishable from the real thing after a period of use..….other than maybe using superior materials if the part was crap back in 1972 the reproduction will be just as crap today!
    There's also a conversion kit on his website… http://www.bencoles.co.uk/
    Cheers,
  3. #43
    Who is going to look inside the distributor. Proper rotor phasing is a much better idea, trigger also. Gled
  4. #44
    That's one of those "well, I know it's in there" scenarios.
    -Marco
    TLG Auto: Website
  5. #45
    Aug 2011
    UK
    Old school fabrication…..
  6. #46
    Aug 2011
    UK
    Nearly there…..
    Distributor bodies now largely complete, other items off for heat treatment then onto assembly…..
  7. #47
    Great stuff for sure. I admire these guys carrying the heavy load for the rest of us.
    FWIW: For those wanting twin plugs on a budget I have it on very good authority that there will be a dual plug cap for a single plug distributor along with a CDI box of which you will only need 1 and a single coil.
    Coming next Spring.
    Early S Registry #235
    rgruppe #111
  8. #48
    May 2011
    Chelsea, Québec
    Awesome work in the true sense of the word...
    Member #1616
  9. #49
    Aug 2011
    UK
    I guess that often with these types of project things take a little longer than hoped……
    ….getting close now, moulds complete and ready for first casting……
  10. #50
    Aug 2011
    UK
    3.0 RSR Spindles…..
    I was asked if I had seen the centre lock spindles for 3.0 RSR, 935 etc that Ben produces as he hadn't seen them on his website yet?……
    …..well he only produced them about 9-10 months ago so hasn't yet got around to advertising them! …..but here's a few photos….
    Cheers,
