With my engine assembly fast approaching I've been hassling Ben to get my dizzy finished....
....this week has been all systems go! .....
https://www.youtube.com/watch?v=PtFtj6SzXKc
Darren
72T 2.5 RHD - http://www.early911sregistry.org/for...l-Street-Racer - http://www.ddk-online.com/phpBB2/vie...p?f=10&t=56183
73 2.4E LHD - http://www.ddk-online.com/phpBB2/vie...p?f=10&t=44242
77 Carrera 3.0 RHD...to 74 3.0RS - http://www.early911sregistry.org/for...?147548-Flares
Early 911S Registry #2325
DDK #601
Things looked pretty good when dyno tested too ......
https://www.youtube.com/watch?v=9Ibt...ature=youtu.be
Darren
DDK #601
Darren
DDK #601
Darren
DDK #601
...more originals for comparison...
...I added the condensers which need the wiring and brackets amended, other than that I think these looks pretty damn perfect ....
....I'm told a few coatings of WD40 will take away the shiny new gleam...
...and side by side...
....dyno tested to ensure a perfect 13º curve and perfect in every detail.......do reproduction parts get any better?
In my opinion just simply awesome!
Darren
DDK #601
Impressive! Beautyfull!
Can't see any points, will you use capacitive sensor?
A rough idea of the price?
Olivier.
...I'm a traditionalist Olivier!
Best to speak to Ben regarding price.....he offers three options, a full reproducyion dizzy that's correct in every detail, a unit with Bosch type internals or just the casing for you to fit your own internals. In my opinion the cost is great value and far less than you'd expect.
Cheers,
Darren
DDK #601
Darren
I am in for both the fan hoisng and the distributor with Ben
Did you use Bens's smaller fan shroud in you "mongrel" build if you did thats good as I at least know someone makes an engine shroud to fit the smaller fan shroud
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Hi Clyde,
The fan housing in the car at present is the smaller type although it's an aluminium housing I purchased from Crawford Composites which was then black anodised, Ben hadn't produced them when I was originally sourcing one. It looks pretty good although I may swap to one of Ben's correct magnesium housings which are exact reproductions of an original. ..........just need to save a few pennies and recover first!
Ben's products on my engine include high butterflies, racing oil filter housing with disk filter, Magneti Marelli twin spark distributor, MFI pump brace and base plate along with a few other items......the glass shroud came from Nick Fulljames at Redtek Engineering....
Cheers,
Darren
DDK #601
Btw.....I plan to vist Ben in the next week or so and will post a few photos to conclude this thread.
He's also produced a few more items including front hubs and the RSR crankshaft pulley etc.
Cheers,
Darren
DDK #601
