Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Weber Carb Cleaning with an Ultra Sonic Cleaner
    Quote Originally Posted by pu911rsr View Post
    These generally have stainless steel tanks and should be ok with any solvent. I'd be careful using anything flamable as they are not made to be explosion proof.
    Phil
    SS tanks are fine. Just wondering about the seals in the pump. Try it with some Berryman Chem-Dip, then let us know how that works. That's nasty stuff.
    Sherwood
    PS: PineSol. Avoid using full-strength on aluminum and copper.
    Senior Member ghalperin's Avatar
    Apr 2014
    Newport Heights, CA
    Sharpertek 1220 Degreaser / Carburetor Cleaner
    Common sense and the warning label on the machine, both tell me not to put anything flammable in there, definitely not Chem-dip. The whole point of this is to avoid Chem-dip. I can still remember what that nasty stuff smells like and it's been years.
    I tried some simple green and the results were marginal.
    I then purchased Sharpertek 1220 Degreaser / Carburetor Cleaner and the results were very nice. The chemical is specifically designed for cleaning carbs and I'm pleased with the outcome. I used about 3 oz. in a gallon of hot water.
    From this:
    Name:  IMG_3531 (Small).JPG
    To this:
    Name:  Weber 4 (Small).JPG
    Name:  Weber 3 (Small).JPG
    Glenn Halperin
    Early 911S Registry Member #2956
    Great info gentlemen thanks. I will be trying the Sharpertek 1220 Degreaser / Carburetor Cleaner and water solution on my carbs.
    Thank you,
    http://the911den.com
    Instagram / UberPorsche930
    Member # 2443
