Hi all,
I´m new at this forum. My name is Angel, and I´m from Spain.
I am considering the budget of a Viper Green 2.7 Carrera RS 1973, VIN number 9113600939. The car is in France.
Does anyone know anything about the life of this car?
Cheers!!
Angel.
Hi all,
Cheers!!
Angel.
VIN = 9113600939
Eng# = 6630926
Trans# = 7830917
Prod# = ?
113 = West German delivery
383812 = Viper Green (1 of 79)
P = Pirelli tires
419 = retractable seat belts, left + right
452 = Blaupunkt Frankfurt w/ automatic antenna
March '73 production
Gruber/Konradsheim
HtH
Last edited by LongRanger; 06-11-2017 at 10:31 AM. Reason: corrected engine + trans #s
Uppss
Thanks LongRanger, but I have the Porsche Certificate and the engine number is 6630926 and gearbox 7830917
Could you confirm it?
Here's a list of all the RS numbers
http://www.lehrenkrauscafe.com/vbfor...ad.php?p=66656
I know that list, but engine Number is also wrong
LongRanger could you please insert a photo of the page refered to this VIN?
Your numbers are correct Angel, engine is 6630926 and transmission is 7830917.
Not sure where Rick got those numbers. The engine # he listed is for an RSR.
I can send you the production number on the lower dash if you like to verify the number on the car you are looking at.
Brian
'71T
R Gruppe #299
Yeah --- that eng# does look a bit 'off,' don' it?
I'm away from my G/K, right now --- but anyone w/ a copy can check, as well . . .
Meanwhile --- I'll double-check this stuff myself, Saturday
On the other hand . . .
. . . Our Esteemed Mr Fryar has WAY better contacts + sources for this stuff than anyone I know, so . . .
I can send you the production number on the lower dash if you like to verify the number on the car you are looking at.[/QUOTE]
Of course fryardds, send it to me. I need all the information anyone could have about this car. It´s quite a big budget and my legs are trembling!!!
Where can I find the production number on the car?. Can you show a photo?
Where is the car located?
If you are new to this kind of car, I can only advice you to inspect it with someone who knows well this kind of car.
You can also try to contact the Club RS de France: http://clubrsdefrance.com/
Even if this car is not listed on their registry, they may know it.
Was is restored recently, and if yes by who?
The 7 digit number is stamped into the metal on the lower portion of the dash, just below the radio and to the right of the ash tray. If the interior is in the car you will have to remove the lower right dash pad to view the number sequence. Here is the location and number from my RS.
I will send you a private message about the production number for the RS you are evaluating.
Brian
'71T
R Gruppe #299
