Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: 911 301239
  1. #11
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by 301239 View Post
    Hi Jim
    Any idea was the 931 optional equipment stand for? also have a VW bus (1956 microbus) and a 356 (1956 speedster) as you
    I have to agree with preS, it most likely means you have Blaupunkt Frankfurt radio no. 723931. Blaupunkt Frankfurt serial numbers were in that range in 1964-1965.
    All the option numbers were four digits starting with 9.
    The best thing for you to do is call PCNA, tell them you're having trouble interpreting your CofA and ask them to clarify. Many people have gotten revised CofAs--given the price CofAs shouldn't be ambiguous.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  2. #12
    Thanks Jim
    Quote Originally Posted by NeunElf View Post
  3. #13
    Got it, Thanks Richard
    Quote Originally Posted by preS View Post
    More likely is it Frankfurt no. 723931
    Just my $.02
    Richard
  4. #14
    Still mssing a lot of interior parts , Fan shroud and fan, Solex manifolds. came with the Solex and a set of Webers but no manifolds.
  5. #15
    Senior Member pss's Avatar
    May 2014
    Netherlands
    John in wich part of the hood , should I look, Thanks.
    Indeed, I have been trying to find that as well some time ago in a dark lit garage. Unfortunately both my cars are not close to my home, so cannot easily check now. Where would that number on the hood be?
    Will look later for my Webasto-number (car 301379).
    301239: interesting to see that your car does not have the luggage hooks. My 301379 does not have that either, but my 300700 does have that (will post picture later). I know 300720 does not have it, but could have been forgotten in renovation. Does anybody know when that changed?
    Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  6. #16
    Thanks PSS ; Yes Please let me if you find where that number should be , probably mine is not og to the car since I inspect every cm of it without luck.
    Omar
  7. #17
    Quote Originally Posted by pss View Post
    Jacques
    FYI, in the first picture in thread #5 the luggage hooks are clearly visible.
    Just my $.02
    Richard
  8. #18
    Sep 2006
    La Quinta
    #301111 has the luggage hooks and the hood number on my car was where the hood and the hinge bolt together. Sorry I don't remember which side.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  9. #19
    May 2014
    Netherlands
    Wow, so 301111 as well as 301239 (sorry I missed them in the pics at first) have the hooks and 301379 does not have them. Jim, can you confirm yours does not have the hooks? This would definitively narrow the change moment down to May 1965.
    By the way, my original 912 Mar 1965 also does not have it (Karmann produced number 450186), but that might be due to the fact it is a 912, maybe they did not have the 'luxury' item at all?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  10. #20
    May 2014
    Netherlands
    My Webasto is 01557 for the 301379.
    This is some 70 away from Jim, although car numbers differ only 3.
    It is some 700 away from Omar, although car numbers only 140.
    My 300700 car has Webasto 00106
    My conclusion is that the Webastos were also used for the 912's from one and the same series.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
