Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: 911 301239
  1. #21
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by pss View Post
    My Webasto is 01557 for the 301379.
    This is some 70 away from Jim, although car numbers differ only 3.
    It is some 700 away from Omar, although car numbers only 140.
    My 300700 car has Webasto 00106
    My conclusion is that the Webastos were also used for the 912's from one and the same series.
    Webasto was probably supplying gasoline-fired heaters to other customers--they still sell gasoline & diesel-fueled heaters. They probably sent a couple big shipments a year to Porsche and they probably were put on a shelf at Porsche. They may not have come off the shelf in the order Webasto made them.
    According to the 1966 Accessories price list, the "Gasoline-electric auxiliary heater" was option 9229. It was a zero cost option on the '66 911 and cost DM 650/US$ 162.50 on a 912. My earliest 911 brochures suggest it was standard on the '65 911 which may not be a big distinction. At any rate, I don't think too many 912s have Webasto heaters. I blame the supply chain for the variance in heater numbers.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  2. #22
    Nov 2002
    San Dimas, CA
    Wow, so 301111 as well as 301239 (sorry I missed them in the pics at first) have the hooks and 301379 does not have them. Jim, can you confirm yours does not have the hooks? This would definitively narrow the change moment down to May 1965.
    By the way, my original 912 Mar 1965 also does not have it (Karmann produced number 450186), but that might be due to the fact it is a 912, maybe they did not have the 'luxury' item at all?
    I don't know what these luggage hooks are. That's not exactly the same as confirming I don't have them so if somebody can give me a better idea what to look for, I'll check.
    Jim Alton
    Torrance, CA
  3. #23
    I am still confuse if mine has it or not.
  4. #24
    Webasto match
  5. #25
    Quote Originally Posted by NeunElf View Post
    Webasto was probably supplying gasoline-fired heaters to other customers--they still sell gasoline & diesel-fueled heaters. They probably sent a couple big shipments a year to Porsche and they probably were put on a shalf at Porsche. They may not have come off the shelf in the order Webasto made them.
    That makes perfect sense since virtually all the 911s up until 1967 model year in my data base, including most all U.S. cars had a Webasto and also why it is listed on their kardex in the option section. On the other hand, virtually no "normal" U.S. 911s had Webastos. Thanks.
    -Allen-
  6. #26
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Unfortunately my car is not close by and I do not have a picture. Here is the hooks on Omars car in the pic he sent earlier. I always wondered when they disappeared, but now it seem it was in May 65.
    Name:  luggage hooks1.png
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  7. #27
    Sep 2006
    La Quinta
    That must be correct.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  8. #28
    May 2014
    Netherlands
    There should be 4 luggage hooks in the luggage compartment. I could not find the top ones in Omars pictures before but a closer look shows the one on the drivers side.
    Here are pics of my car's hooks 300700 from March 1965.
    This is the lower front one (passenger side)
    This is the higher one, just behind the strut (passenger side)
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  9. #29
Size:  213.6 KBName:  unnamed-3.png
Size:  183.4 KBName:  unnamed.png
    Here some extra pictures of my car in that specific area, I only can find 2. will see the car in flesh this next saturday and confirm.
    Now, Can anybody around reading this can share some knowledge and help me , need to know where to get a set of heater pipes(tubes)
    in the US? the ones that runs under the rocker panels. Pleaase..
    Omar
  10. #30
    Nov 2002
    San Dimas, CA
    Ok. My car, 301382, does NOT have these luggage hooks.
    Jim Alton
    Torrance, CA
