Hello,
My name is Jill Harris and I am the wife of the late Bill Harris. I am selling his 911R built car. Below are detail and pictures of the car. Please email me with interest in the car. jbkharri@msn.com
Asking Price: $70,000
Body
Grand Prix white with tangerine stripe; All painted in Acrylic Urethane single stage
Black 911R vinyl scripts
Bare metal strip to exterior tub
New floor pans and suspension pan installed by PO
911R steel flare custom formed and butt welded
RSR type hood with balsa and amber liner
911R front fender with bucket custom to Werks spec
911R front bumper to Werks spec
911R rear bumper to Werks spec
911R rear deck lid with amber liner
Steel early doors converted to 911R interior spec
911R plastic door handles
911R rear tail lights with lights
911R engine lid grill
Rear lid hold downs
Hood hold downs
911R stainless lid hinges
911R acrylic vented ¼ window with trays
911R Acrylic door vent windows with spin vent
Acrylic door windows with leather pulls straps
Leather door stops
911R front turn signal / side marker lights
911R Bi iodine headlights
New front /rear windshield rubbers
New door/ hood/ body 2 bumper seals
Large round durant mirror
Chassis stiffing engine compartment shock towers
Chassis stiffing at torque tube
Interior
911 R style race seats with basket weave inserts
Werks type roll bar
Perlon carpet kit
Dead pedal
New German vinyl off white headliner
Early dome light
5 point harness
Chrome SWB rear view mirror
Momo period correct steering wheel
Clock delete
Radio delete
Drive Train
Engine
Core starting motor 1982 large port long block
Static / dynamic balanced/ new bearings/ chains/ ring/ gaskets
Build install motor
3.0 crankshaft STD/STD polished
Rods resized/ rebushed/ balanced/ ARP rod bolts
J&E pistons 10.5 : to 1 pistons/ rings/ wrist pins
3 angle grind valve job
Regrind 4 journal cam shaft to S Spec Web Cam
40mm Weber carburetors rejected to 3.0 S spec tall PMO manifolds
908 style rain shield with tall air horns
RSR amber shroud and tins
3.0 recurved distributor
Bosch unshielded spark plug wire set
Pulstar Platinum spark plugs
MSD 6AL ignition and coil
1 5/8 RSR style headers
Biscoff muffler converted to Werks rally spec with baffles
KEP 215 mm performance flywheel / clutch pack
RSR motor mount
3.2 Alternator/ fan
3.2 starter
993 oil filter console ( replaced engine oil cooler
Transmission
1967 aluminum 901 5 speed
MSX gears
Nice dogs New Scyros hubs
1900
Oil System
1972 911 oil tank
External 80mm filler neck
Aluminum 80mm filler cap1972 911 S oil filter housing
1988 Carrera front oil lines and fender cooler
Coline oil lines custom fitted
911R overflow tank ( SWB washer bottle)
993 2nd oil filter housing (replaces engine oil cooler
Fuel System
100 ltr Rally type fuel tank with 100mm though hood filler neck
Holley Red fuel pump
Holley fuel pressure regulator and gauge
Suspension
1988 Carrera front suspension
Boge 3.5” struts painted orange
964 4- piston calipers
Stock Carrera front torsion bars
RSR type front sway bar 15mm
964 4 -piston rear calipers
Boge rear shocks painted orange
Carrera rear adjustable spring plates modified for SWB
Stock Carrera rear torsion bars
RSR style rear sway bar 19mm
Dual master cylinder pedal assembly
Tilton masters 5/8 rear ¾ front
15X 6 Deep six wheels polished and shadow painted
195front tires 205 rear tires
80mm wheel studs
Open steel lug nuts
RSR front strut brace
