Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
Thread: 1973 Oil Tank Questions
  1. #51
    Honestly don't know if that is the original tank drain plug Steve. I have a later oil pump with no sump drain so that plug for sure is gone.
  2. #52
    The Netherlands
    Original drain plug. At least the ones on the three 1973 only tanks I have are the same.
    Cees
  3. #53
    May 2012
    UK
    Did you mean to add photo Cees or are you referring to example posted by David ?
  4. #54
    I would encourage anyone using the 19mm hex drain plug to use the new 15mm one. The threads are very shallow on the 19 and I have seen tanks stripped out. The new 15mm one has deep threads, use without worry, and tell the concourse judges it’s a Porsche update.
  5. #55
    Feb 2003
    Los Angeles
    This is helpful. Do you happen to have a part number for the improved drain plug?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  6. #56
    May 2012
    UK
    Quote Originally Posted by Bert View Post
    Was there an earlier in-hex version of the tank plug or was it always 19mm hex in 72/3?
  7. #57
    The Netherlands
    Quote Originally Posted by 911MRP View Post
    Example posted by David. When I am back home I can post a picture of the ones I have.
    Cees
  8. #58
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    This is mine from a late June/ early July 1973E (very close to the last one made.
    I believe that it is original to the car
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  9. #59
    The Netherlands
    One from the net:
    Cees
  10. #60
    May 2012
    UK
    Quote Originally Posted by HughH View Post
    Hugh is the shape of this late tank the same as David’s tank also assumed original shown in photos in post #49? Think it is the case as you showed it many posts back. If original it would suggest the use of the different shape tank only began quite late in model 73 production annual cycle.
    The hex looks taller than Cees www example ?
