Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Early 911 engine type 901/01
  1. #11
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Very interesting indeed. If the cast is indeed 64 and early 65 then I guess it should be a 901/01. If the right half of the case is Jan 66, then could it be that the original right half got damaged and this is a replacing piece with a new overall number (KD), but the original 1099 number?
    Do you know which car this came from?
    Davep, help......
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  2. #12
    The number on top, 422, is the pairing number. The other half should have the same number. If so it means the 2 halves form 1 case. I have seen more cases with different cast dates and these are not very far apart.
    It is possible to look up the kardex of the car via the engine#. The engine specs should be on the kardex.
  3. #13
    May 2014
    Netherlands
    indeed Ronnie, can you check whether you find the 422 on the other half as well?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  4. #14
    Yes- both halves have the pairing number 422. I had left out the picture of the other side.
  5. #15
    Hello-
    I decided to sell the engine- It is on Ebay for those that may be interested. I have details of part and casting numbers with dates listed in the ad. The crankcase is 64/65, heads are 65, timing chain housings 65. Intake valve covers are 65.
    Cam boxes are 68, with later exhaust valve covers. The ad has hi-resolution pictures- I have to add pictures of the internals. I appreciate any help/input you all may be able to provide.
    The money from this sale will be used to help fund another car. I sold my Turbo in 1999 and have been driving Chevy's ever since.... Thanks again to all, including the staff that makes this site available!
  6. #16
    Hi Ronnie. A link to the add would be helpful
    early S registry # 2596
  7. #17
    Nov 2002
    San Dimas, CA
    Probably eBay item number: 232344800104 Porsche 911 engine 1965 type 901/01
    http://www.ebay.com/itm/Porsche-911-...5/232344800104
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  8. #18
    That is the Ebay auction. Thanks for posting the link, I did not know if linking to auction sites is allowed.
  9. #19
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by pss View Post
    Davep, help......
    Better late than never, the original engine # to go with build 1099 was 901199. In my opinion the engine was renumbered, perhaps by the factory, but difficult to know.
    The official end of type 901/06 was engine serial 912050; this is 7 beyond that. Perhaps the factory recycled engine cases, but I have not heard that happening before.
    This case is a curiosity piece.
  10. #20
    There is a very slight chance I have some paperwork from the car. Will look tomorrow.
    I seem to recall the car having an early serial number. A very foggy memory of a Porsche 'expert' looking at the rear cross support that has the engine lid latch mounted. He commented that it wasn't original because it was different- IIRC it did not have the recesses stamped into it....
