Page 27 of 35 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 343
Thread: 1971 911t
  1. #261
    Jul 2014
    Long Island NY
    can you take the defroster vents out without taking the dash off.?
  2. #262
    Quote Originally Posted by sebastianroher View Post
    Thx!
    I'll try next time I'm at the shop!
    Start with the clock, use a spudger around the rubber to release. then slowly pull. Once you have the clock out you can help push the speedo from the rear, then the tach. Proceed to the others or start from the other end with the fuel gauge.
  3. #263
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    Quote Originally Posted by Jrsully View Post
    I popped mine out today with the dash in place.
    1971 911t coupe
    2002 Camaro z/28
  4. #264
    Jan 2015
    Florida
    Thanks David!
    I'll definitely give it a try and report back!
    1971 911t coupe
    2002 Camaro z/28
  5. #265
    Jan 2015
    Florida
    Making progress
    1971 911t coupe
    2002 Camaro z/28
  6. #266
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Where on Earth did you get those wheel dollies.............?....cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
  7. #267
    Jan 2015
    Florida
    Quote Originally Posted by Cliff View Post
    They're my body guy's... not sure, but I can ask him!
    1971 911t coupe
    2002 Camaro z/28
  8. #268
    Congratulations on your effort and progress. Reading though the thread was enlightening to say the least. Comment on your deck lid. I have a later one correct for your car.
    The one you have adds a little character to your car even if incorrect. If you decide to upgrade I can help.
    later,
    Rusty
  9. #269
    Jan 2015
    Florida
    Anyone have any experience installing the stoddard stainless steel fuel line through the center tunnel?
    1971 911t coupe
    2002 Camaro z/28
  10. #270
    That's not something you normally have to replace, so little experience. I think we've done one because our careless apprentice drilled thru it. As I remember it removes and installs from the front. You need to remove all the assemblies from the tunnel so you can access the hold-down tabs (which it looks like you've already done) Not a tricky job, just put it back like you found it! And be sure to get it in the rubber grommets at each end.
