Page 32 of 35 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 343
Thread: 1971 911t
  1. #311
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Seb,
    Posted the part # on previous post.
    Mark
  2. #312
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    Ed, Mark, Keith,
    Can you tell me if the pan I have from Restoration Design has the part you mentioned? (It looks like it does) See pic #2
    Seb
    http://www.restoration-design.com/store/product/PP200
    1971 911t coupe
    2002 Camaro z/28
  3. #313
    Feb 2017
    Auckland NZ
    I think your all good there fella,
    Looks like RD are making some nice stuff.
    mark
  4. #314
    Jan 2015
    Florida
    Quote Originally Posted by NZVW View Post
    mark
    Mark, yeah they do make some pretty good stuff. I purchased inner/outer rockers from them as well as parcel shelf. I'm hoping it all comes together nicely once I get the gas tank support panel.
    Seb
    P.S. been thinking about saving up for a set of ST flares....
    1971 911t coupe
    2002 Camaro z/28
  5. #315
    Feb 2017
    Auckland NZ
    Seb,
    This part is one that should not be rushed when fitting
    As you know it basically aligns the whole front end so just take your time and it will work out.
    Plenty here know a shXt load more than I and as you know they are super generous with their knowledge, shout out if concerned and Im sure someone will assist.
    Mark
  6. #316
    Jan 2015
    Florida
    Seb,
    Mark
    Mark, I understand. I've watched the video of Restoration Design and I am being supervised by a friend who used to do this type of work for a living for many years. I'm open to any tips or suggestions from those who have done this repair before, I definitely wouldn't have attempted it on my own!
    Seb
    1971 911t coupe
    2002 Camaro z/28
  7. #317
    Seb, it's not shown in the picture, it's a part that has to be welded in.
  8. #318
    Feb 2017
    Auckland NZ
    Logic prevails
    Cut out the rot (hopefully within the replacement parts dimentions)
    Temperary screw or spot weld when aligned
    Check, check and re check
    Mark, cut, weld.
    20 minutes max lol
    Later,
    Mark
  9. #319
    Feb 2017
    Auckland NZ
    Ed,
    So is it Part # 901 501 427 21
    Front Suspension Mount Reinforcement , To be welded in after suspension has been bolted in correct placement ??
    Mark
  10. #320
    Jan 2015
    Florida
    I may give the Canadians a call tomorrow to verify. The pic on their website looks identical to the part Ed mentioned.
    Seb
    1971 911t coupe
    2002 Camaro z/28
