Results 1 to 7 of 7
Thread: 70 E trunk color
    70 E trunk color
    I understand the undercoat area and all but I am told the entire area in luggage/ fuel tank area is satin black, under coat area and non under coat area.
    Only two rear choices here black or the color of the car, what say you concours guys
    70 was the first year for body color overspray in the trunk area over the undercoat. The engine bay had body color overspray on the undercoat, then was finished in satin black over that. Rub off the black and you'll find body color overspray. LOTS of threads on this!
    So trunk/fuel is body color and engine bay is black
    Seems odd but that is how we will go forward
    Jul 2006
    Switzerland
    yes, as Edmayo said but the body overspray in the trunk was just one coat sprayed, so kind of "transparent" body color and its very mat (no shine) you can almost see the metal. Engine bay is black but as Edmayo said, there is body color underneath. My car is like that.
    BTW, wheel areas are black as undercoating below the doors/trim.
    Do a search for details on unrestored cars as that area is often wrongly done.
    Registry member No.773
    here you go - a couple of shots from my old car that might help - original
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Please also keep in mind 1970 Karmann bodied cars had noticeably more black paint applied in the front trunk area than factory bodied cars
    Quote Originally Posted by boxster03 View Post
    boxter03 - Very Nice!
