Results 1 to 10 of 20
Thread: tires/wheels on a 68 & a 69 ???? help please
    Senior Member GT3DE's Avatar
    Nov 2012
    Arlington, Virginia
    tires/wheels on a 68 & 69 ???? HELP PLEASE
    I have four (4) deep 6 hearts and four (4) 7Rs, freshly refinished from Harvey.
    I have two cars that I wish to use these on, a 68 and a 69.
    I have a 68 narrow body swb longhood - stock body - with a carb'ed 3.0L.
    I have a 69 narrow body lwb longhood - stock body - with a carb'ed 3.0L.
    These are sleeper cars - look stock outside, bigger motor.
    Both cars will have a lowered stance.
    These are warm weather (50 to 90 degrees) sunny day cars that hopefully will not drive in the rain, but need to allow for the possibility from time to time.
    Need some help from the e911s crowd:
    * Will the 7R's fit in the stock rear fenders?
    * Will they need spacers (what size)?
    * What tires (front and rear) should I run on these wheels on these cars?
    Thanks for the help,
    Clarke
    Clarke
    Early S Registry member #3172
    Current
    Race: 10 GT3 pca-GT2, (2) 78 911 pca-E 3.2L
    Street: 05 997S Launch, 75 911S Gemini Blue 3.0L, 68 912
    Past
    68 912, 68 911, 69 911T, 71 911T, 72 911T, 73 911T, 73.5 911T, 75 911S, 77 911, 82 911SC, 91 964 C4, 02 996 cab, 05 997S Launch, 06 997 C4S cab, 10 Cayenne GTS, 11 GT3RS, 11 GT3RS
    "I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." Arthur
    May 2005
    Oroville, CA
    I would agree with Eric. His set up is at the max and not for the faint hearted.
    I recommend on the SWB...205/60 with 7R on the rear and 12-15 mm spacers and 185/65 with 6 on the front. (See Bridgers car)
    On the LWB...215/60 or 225/50 with 7R on the rear and 12-15 mm spacers and 185/70 (or 195/65, 205/60) or 205/50 (or 205/55) on the front.
    Even some of the 215/60s can be close so trial fit everything.
    Race car sizing is different so be aware of their recommendations.......
    H
    Nov 2012
    Arlington, Virginia
    Thanks E and Harvey. How about tire brand/model/type, please?
    Clarke
    Current
    Past
    I am currently considering for my lwb with 7Rs and deep 6s the p6000 pirellis . They now make 185 70s AND 195/65s as well as the 215/60, any opinions on these?
    Senior Member Aldo's Avatar
    Dec 2007
    Austin Texas
    Clarke- My 68 swb with deep 6s sees the same warm weather use as your cars. Not exactly period correct, but I'm running Yokohama Ao48 (205/60)- a lot of tire for my 912, I know, but with the sticky tires and low power the car is nearly imperturbable! :-) On your swb cars with 3.0 power and weight, that extra stick might come in handy.
    Alan Domme
    Austin, TX
    '68 912 coupe
    '16 VW Golf R
    Early 911S Registry #1361
    912 Registry
    Nov 2012
    Arlington, Virginia
    Had to look it up - imperturbable
    im·per·turb·a·ble
    ˌimpərˈtərbəb(ə)l/
    adjective
    unable to be upset or excited; calm.
    "an imperturbable tranquility"
    synonyms: self-possessed, composed, calm, cool, and collected, coolheaded, self-controlled, serene, relaxed, unexcitable, even-tempered, placid, phlegmatic; unperturbed, unflustered, unruffled; informalunflappable, unfazed, nonplussed, laid-back; rareequanimous
    Clarke
    Current
    Past
    Nov 2012
    Arlington, Virginia
    ok, how about this idea? - please post pictures of cars with deep 6 fronts and 7R rears (and if you know what tires, please list details).
    Clarke
    Current
    Past
    Using Good Year Eagles on my deep 6 Fuchs on a 69: 195/70/15, I can't find 185's but they clear the well and work like a champ. Grippy.
    Jan 2003
    UK
    On a lwb car with deep sixes (F) & 7R's (R) my preferred make/size of tyre is:
    Deep sixes + 185/70 VR-rated Avon CR6ZZ
    7R's + 215/60 VR-rated Avon CR6ZZ + 15mm bolt-on spacers (we call them wheel adapters over here)
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Nov 2012
    Arlington, Virginia
    Searched the web cannot find those Avon's listed by Andy in above post.
    Any reason this combo wouldn't work?
    Toyo Proxes RA1 205/50 & 225/50
    Clarke
    Current
    Past
