Results 1 to 2 of 2
Thread: Removing front vent windows
    Is it possible to remove the front vent windows in order to replace their seals, without removing the complete window assembly? Any tips either way appreciated. Working on a 73' Targa.
    Thnx
    Mike
    No, because you need to remove the vent glass to do the job. And it is retained by bolts only accessible when the frame is out.
