Thread: A and B pillar vinyl pieces
    Hi all-
    These are the pieces of vinyl remaining that I think are for the A and B pillars.
    It looks like I'm missing the upper B pillar covers, correct?
    Also for the A pillar, I assume the bulbous part is at the top. How far down does the vinyl start? Or, perhaps, how far up the pillar does the vinyl go? Any pictures of the upper trim over headliner?
    Thanks a lot!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Thin section goes towards the top in both, although my origional that I used for patterns were nowhere near that wide at the base, as the second ones in your photo.
    I'd say the bottom ones were ment to fit the knee bolsters, looking at the pattern shape.
    I fitted my roof-liner, and then the B pillar, and carried that line/height to the A pillar, and it was very close to the marks that I'd placed on the pillars from when I removed them. The fold back that I did on each piece was 5mm.
    Hope that helps.
    Tony
    Thanks Tony! Yes, those must be for the knee pads, which I didn't think I ordered...
    So I need the A pillar and upper B pillar pieces. Thanks again!
    Cheers,
    Ron
    Nov 2004
    Gold Coast.
    I would have said the top one in your photo are either for the A or B pillars.
    If you don't need to cover your knee pads, I think you find there's enough vinyl to to the A or B pillars in the second set in your photo.
    Tony
