Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: #11800250
  1. #11
    Those are Zeniths, not Webers, but the above answer still holds.
  2. #12
    Junior Member
    Apr 2015
    Madrid, Spain
    You are right, thank you!
    Tha cae has a ser of Zenith 40TIN...were they
    standard or óptional in 1967?
    I'm searching for a set of Weber 40idt or 40ids, am I right?
    Kínd regards.
    Early 911S registry Mbr 32.
  3. #13
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the heating system on a LWB is completely different as on SWB....does your car have the heater sliders in the door sill?
    ashtray,dash,mirror,bat boxes,etc..... are also different
    68 is a very odd model with many `68 only details.
  4. #14
    Oct 2012
    New Mexico
    I think you should investigate more what you have. Nothing about that car appears as a '68 911S.
    '69 on fenders
    '69 on taillights
    '69-'71 decklid grille
    911T bumper trim
    '69 on door window frames
    '70 on door handles
    '69 on fan housing
    '70 on MFI fan shroud
    fuel return line in engine compartment
    '70-'72 zenith 911T carbs (no, not available in '67!)
    '65-'68 engine (based on sand cast chain housing covers)
    This is a very strange beast. Maybe take a very careful loom at the VIN numbers.
