Results 1 to 9 of 9
Thread: Rechrome switch stalk
    Searched the site but can't find anything appropriate. Picked up a couple of working switched from a '67 that are in good working order. However the handle stalks need to be re-chromed. I cant tell if the pivot point is apin that has to be pushed out or is this a rivit that needs to be drilled out
    Assuming somebody can tell me the proper procedure for removing that pivot the next question seems to be how to get the handle off. Can't tell if it merely held there by compression or some type of glue was applied. Sierra Madre has replacement handles but I worry that if this is removed by crushing/breaking, that upon re-chroming the diameter of the hand stalk will be too large to accomodate the diameter of the hole in the handle. Don't know if I have been clear enough, but hopefully someone who has done this in the past will perceive the problem
    Thanks in advance for any help
    Tom
    Fantastic. Many thanks. To the moderator: Tried the words "wiper", "stalk", rechrome" and search did not seem to come up with this thread. Am I missing something? See comments all the time like "search is your friend" in response to inquiries of others. Why didn't my words reveal this?
    Tom
    Sep 2009
    UK
    Tom, you neeed to search in Google for the best results. Something like this. early 911s registry forum indicator stalk site:www.early911sregistry.org
    Thanks Stretch. I'll try that approach next time. Aside from that the thread answers all my questions
    Tom
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    In case you need it, here is a nice guide how to search using Google as mentioned by Stretch: http://www.early911sregistry.org/for...egistry-forums
    This has been a lifesaver for me!! :-)
    S-Reg #1382
    67S Lavender
    Jan 2011
    Sunny Southern France
    Just a thought for breaking the glue.
    Sometimes, a couple of hours in the freezer achieves the same result. Worth trying in order to avoid playing with a heat gun on the old plastic...
    Olivier.
    Great suggestions all as to both issues.
    Tom
    Nov 2010
    Port St Lucie FL
    site:early911sregistry.org weird part
