Results 1 to 2 of 2
Thread: Paint Manufacturer
    Paint Manufacturer
    1972 911T.
    Who was the paint manufacturer referenced in 936-9-3?
    Not quite correct. 1970 & 71 had the xxxx-y code and from 1972 the coding changed to xxx-y-z.
    The 70/71 code was actually 2 digits for body and 2 digits for roof followed by the paint manufacturer letter. So if the paint code was 80 (silver) then a coupe would be 8080 if it was all one color; and I have never found a two tone coupe. The targa would be 8010 where 10 was black for the normal targa top; I guess other colors were possible, but I've not found one yet.
    The coding for paint manufacturers that I have worked out are
    1 L Lesonal
    2 G Glasurit
    3 H Herberts
    4 HL Herbol
    where first column is the 72+ code, and second column is the 70/71 code
    Seek and you shall find.
