Thread: Quarter window seals
    Hi all-
    Is there a seal that mounts on the body side of the quarter window? I just ordered the seals that go around each window from IM but Terry said he didn't sell a seal that fits on the body. To clarify, I'm not talking about the seal between the glass and pop-out frame; I'm thinking there should be a seal that goes around the window opening over headliner and vinyl trim like a 356.
    This is for a 1969 Coupe.
    Thanks a lot in advance!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    There are three parts involved: a seal around the glass, a seal around the metal frame, and 'U' shaped channel that fits over the pinch weld and covers the headliner edge.
    Sep 2013
    Kalamazoo, MI
    Ed is correcto mundo. But let me add, the "U" shaped channel is actually two pieces. On my "67, a black channel fitting the vertical "B" pillar pinch weld and a white/ivory channel at the top pinch weld meeting the headliner.
