Thread: Recommendations for rubber door seal for 1967
    larryg57
    Oct 2008
    Greater fly over states
    When my 67 was restored, the paint shop used the available "tube style" main door seals. The car has massive wind leaks. Stoddards and other venders have various options for door seals. Which seal on offer in todays market is the most original and functional?
    Thanks for the help.
    Larry
    The first item to check is that the window frame was adjusted correctly when the car was reassembled, that the window frame is actually pushing against the seal all the way around the frame. This is usually the culprit. Check by putting a business card between door and seal, then shut door, card should be hard to pull out, check all the way around. As a final cure I cut the seal in half right where the window frame meets the 'A' pillar (usually the greatest source of noise) install about three " of rubber rope, then super glue ends back together.
    Apr 2011
    N.Calif., south of SF
    Good suggestion Ed. If you have pictures or can point to any threads of
    that would be helpful.
    Years ago I had a refrigerator repairman tell me to test seals the same way using a dollar bill. (Not that sano) but sure did demonstrate where the seal was failing.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    larryg57
    Oct 2008
    Thanks, I'll try the business card test. However, which seal should I use?
    Larry
    Apr 2011
    Larry- A lot has been posted on door seals. I just did a search using: Door + Seal and came up with this
    http://www.early911sregistry.org/for...ight=door+seal
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
