Thread: front sway bar bushings
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Would anyone care to share your technique/procedure on installing the bushings for the front sway bar? Looks like a real chore wedging these pieces into that hole and into the mount.
    At first I thought it might be easier doing one side while the bar is out of the car, but then reason prevailed and I figured I'd get guidance from someone who may have done it a number of times. Thanks for any assistance, Mike
    Dec 2011
    Victorville CA
    I used silicon spray and a hydraulic press.
    Apr 2014
    New York/Florida
    ...thanks ...got it done
    Jul 2006
    Corvallis, OR
    All you need to do is lube it with some dish soap and then use bolts that are longer than the 16mm stock bolts. Tighten each bolt a little at a time until carrier bracket is flush with the body then back out longer bolts and reinstall the shorter bolts.
    72S, 72T now ST
