Thread: Is sand blasting brake rotors Ok?
    Jul 2014
    Niagara, Ontario
    Would like to clean rotors up, is sand blasting OK or is the blasting to harsh on the pad surface?
    Is there another viable option?
    Thank you for your opinions.
    Regards,
    Mike
    hydro blasting works a treat then get refaced at local brake place.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Oct 2010
    Florida
    This shouldn't be a problem if you clean them carefully. I would sandblast them and then hit the disc surface with some 180 paper on a rotary sander to get some random scratches. You don't want to remove any material. You just want to scratch the surface. This helps prevent squeal.
    Then scrub them in hot soap and water. Finish this up with a brake clean rinse. When you can wipe the surface with a paper towel and the towel remains clean you're done. Cleanliness is the key here.
    More brake rotor/disc nonsense here.
    Richard Newton
    Jul 2014
    Niagara, Ontario
    Thanks Clyde and Richard for your help. Just want to be sure I won't damage the rotors.
    Regards,
    Mike
    I'd soda blast them to keep the tooth from the media blasting down. Otherwise, you are going to smoke your pads.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Aug 2009
    SF Bay Area
    Just go out and put your brakes on. One or two stops and your rotors will be shiny bright.
    Jim
