Results 1 to 9 of 9
Thread: Won't Start....help needed!
    Oct 2014
    near Champaign, Illinois
    Gang,
    For about the last week, I have been desperately trying to start my 71 S. I have a stock set up with a freshly rebuilt top end. Last night, I was able to get spark at TDC and seem to have everything static timed correctly.
    Last night, I decided to pour a bit of gas into the MFI stacks thinking that it would fire right up....it didn't. Tried it again....same non-starting result.
    My local guy told me to shoot a bit of oil into the cylinders and to check compression. Does this make sense to anyone?
    Any help is appreciated!
    Jay Yost
    1946 Willys Army Jeep
    1956 356A Cab
    1957 356A Speedster
    1959 Austin-Healey Sprite
    1962 356B Notchback
    1969 911T 'Speedster'
    1971 911S
    1974 Ford Ranchero
    1986 911 Carrera Cab
    1993 Audi V8Q
    2001 Mazda Miata 'Daughters Car'
    2008 Audi S6
    2018 Panamera 4S 'Wife's Car'
    Dec 2008
    Black Mountain, NC
    Sorry missed note on Having spark at TDC, was guessing an ignition issue, CDI or points, could not delete
    Oct 2014
    That was exactly what I thought, but I have spark at the proper time. Verified with my timing light.
    Jay Yost
    1956 356A Cab
    1957 356A Speedster
    1962 356B Notchback
    1971 911S
    1974 Ford Ranchero
    1993 Audi V8Q
    2008 Audi S6
    Oct 2014
    No sweat, Jerry!
    Jay Yost
    1956 356A Cab
    1957 356A Speedster
    1962 356B Notchback
    1971 911S
    1974 Ford Ranchero
    1993 Audi V8Q
    2008 Audi S6
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Have you checked the MFI pump pulley wheel mark on the back of the pump to match to the FE mark past #4 TDC on the crank pulley
    1969 S Coupe #761
    Early S Registry #1624
    I just started one last week for the first time in 15 years. All I do is run a jumper from a hot terminal at the rear fuse box to the solenoid on top of the fuel filter, to manually prime the system. In your case you need the aircleaner on as that is where the spray bars are. Be careful not to over do this, you can also flood the engine if you're not careful. This one started in two or three tries.
    Mar 2006
    Louisville KY
    If the gas down the stacks didn't get the engine to make any noise I would verify that the firing order is correct
    Or the cam timing is correct.
    Tony Proasi
    52 split window coupe
    Go back and recheck everything that has to do with timing. #1 TDC distributor, both valves closed. 360 plus to FE mark, check mark on the injection pump.
    Fuel pressure and flow to spec.
    I would pull a plug and check for over fueling.
    Just a few of the things to think about
    Take you time and breath, it will be okay.
    Rusty
    Oct 2014
    That is what I have done, along with a compression check.
    I also thought that when I dumped gas into the stacks, I might have dumped too much, because when I pulled the plugs, they really smelled like gas.
    Thanks much!
    Jay
    1956 356A Cab
    1957 356A Speedster
    1962 356B Notchback
    1971 911S
    1974 Ford Ranchero
    1993 Audi V8Q
    2008 Audi S6
