Hi,
my 1965 Porsche 912 is at the restorer and he is tackling a problem that he seems unable to solve. He installed and original 1965 hazard switch including the original relay and from that moment on the flasher flashes also when the turn signal lever is used. Interestingly, the hazard switch only flashes together with the turn signal light when the turn signal lever is used in one direction, I don't know if it is to the left or right, but the problem only occurs in one direction.
Any help from the experts would be appreciated.
Regards.
Stefan
