Recently bought front turn signal housings from Stoddard. The new ones have black, red and green wires.
The old ones have black, grey and brown wires. Which wires connect?
Thanks.
Thanks.
Mike
Early 911S Registry #880
356 Registry #30248
1973 911S 2.7 RS spec
1973 911T
1964 356C twin plug
1969 Z28
Brown is the ground wire
Black is the flasher wire
Grey is the pilot light
Well it is on a SWB anyway
Hope that helps
Sean
On the new set which is the flasher wire the
OK from the car the original brown (ground) wire I assume goes to the new assembly black wire.
But " " " " " grey and black go to which new red or green?
Mike
356 Registry #30248
1973 911T
1964 356C twin plug
1969 Z28
I always throw away that silly repro stuff and install the original wiring. Then everything works right and the colors are correct.
without throwing anything away I need to mate 3 wires with 3 wires.
Any help would be appreciated. Thanks
Mike
356 Registry #30248
1973 911T
1964 356C twin plug
1969 Z28
Normally I would get a new harness and be done with it but I really didn't want the expense.
The previous owner cut through the harness at the housing. His plan was to replace the housing and splice the wires.
Well now it's my project and to save money I bought a reproduction housing and lenses but have no idea how these wire
colors match except I know brown is ground. All I want is safe and functional.
I'm at wits end.
Mike
356 Registry #30248
1973 911T
1964 356C twin plug
1969 Z28
Grey w/ red is the marker and black w / white is left turn and black w/ green is rt. turn signal.
I don't have a white wire. Both housings have identical wiring; black,red and green
Mike
356 Registry #30248
1973 911T
1964 356C twin plug
1969 Z28
I didn't mean you had a white wire,,,,,the left side wire is black with a white tracer, the right side is black with a green tracer. As to the wires on the new unit I have no idea what those colors mean, that's where you use the ohm meter to see which bulbs they go to. Then attach them to the proper existing wires in the car. I could never understand why some people cut the wires,,,,,,all you have to do is UNPLUG it at the bulkhead!! Oh, and I would not recommend scotch locks or butt connectors. Solder and heat shrink tubing.
