Thread: Raise front suspension?
    Dec 2009
    Copenhagen, Denmark
    hi guys, I have a 1971 911T, how do I raise the front suspension 0.5 inches or so? It was lowered 1 inch by a shop a while ago without asking and now I scrape my foglights on the drive way. I hear this is a DIY job.
    I found this and it's likely the best resource.
    http://www.pelicanparts.com/techarti...ng_the_911.htm
    James Hurst #1638
    R Gruppe #514
    thats it..ezpz
    Jack the car up to take the weight off the screws, then get turning. Make sure you turn the exact same amount both sides or you will need a corner balance. Alignment will also change with the change in height.
    Dec 2009
    Copenhagen, Denmark
    Thanks everyone. It was a super easy job. And fun.Name:  20150502_142218.jpg
    James Hurst #1638
    R Gruppe #514
