Results 1 to 8 of 8
Thread: parts ID and location help
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Can someone kindly I.D. these grommets and tell me where they go? Thank you for the helpName:  20150504_143332 (Mobile).jpg
    Oct 2011
    The land of fruits and Nuts
    Drain tubes. Appear to be trunk to me but I'm novice. Either trunk or headlight and I vote trunk.
    Porsche taste on a Volkswagen budget...
    newer / later trunk drain tubes for the rear light buckets. They are available at your Porsche parts supplier
    Richard
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    richard how new? 993 or even later?
    i have some of those(came with a big NOS parts lot from ebay) i always thought its some electric connector thing
    About a month ago I bought them and was given these for a 75.
    Richard
    Probably the protective boot for electric injector plug.
    Apr 2014
    New York/Florida
    They are too small in diameter and do not fit any of the drain holes in any of the usual places that I can find, They came in one of the cartons which made up the 72 project that I purchased so I figured they might be used elsewhere on the car. Guess not, maybe a substitution that didn't work out. Again thanks for the help.
    Feb 2012
    Edmonton
    I'll agree with Ed, sure looks like a boot for most Bosch 2 pin electrical connectors.
    Can't think of any use for them on a '72, but they're used for several different applications on CIS and later engine harnesses.
