Results 1 to 7 of 7
Thread: Silly question: rebuilt brake calipers, position back so bleeders up or down?
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    I removed the calipers from my '66 a couple of weeks ago. Promptly used a marker to indicate the right side calipers. Rebuilt them. And in the course of cleaning them, the mark, of course, was wiped away. And I can't remember which way they go back on the car (getting old). Should the bleeders be pointed up, or down toward the ground? Thanks. And proceed to give me the hard time I deserve.
    Joe
    Bleeders always go up because that's where the air accumulates... unless the car is upside down or you are in Australia.
    Dec 2011
    Monroe, WA
    I'll stick up for you…!
    (did the same thing)
    Nov 2009
    DC/Montana
    I thought so. But take a look at the bottom-right photo on page 29 of the most recent Esses. Bleeders pointing down. Someone tell the owner of that beautiful '67 S.
    Nov 2006
    S. F. Bay Area
    Maybe he thought the fluid would drain easier. :-)
    The photo on page 29 appears to show the rear suspension in "mock-up" mode, as the rotor has yet to be fitted, and can not be fitted with the caliper in place, therefore requiring it's removal.
    I trust the owner has them installed in the correct position.
    Brian
    S Reg #1032
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Quote Originally Posted by Flieger View Post
    Ummmm so I've got mine upside down then?
    Tony
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by classic View Post
    Depends. when flushing the loo, does the water swirl in a clockwise or counter-clockwise direction?
    Brian
    S Reg #1032
